Jul 17th, 2024, 7:17am
LNA Design (Read 6256 times)
chris2312
LNA Design
May 23rd, 2011, 9:32am
I'm new in design of integrated circuits. I have to design a lna. I choosed cascode topology to achieve high gain at high frequencies. My problem is to find a bias point with minimum noise of the transistor. I have red that most lna's operate iun class-A, so you have to choose the bias current that Ic = Icmax/2. Othwerwise the shot noise oft the transistor will increase with high current, so i choosed a bias current which is smaller than Icmax/2. I plotted gm vs. NF to find a good tradeoff first for a common emitter stage. Now I want to do the same for the cascode to find an optimum, but I have no idea how to realize it, because of the bias voltage of the load transistor. Can you give me some hints ? Thanks for response.
rfcooltools.com
Re: LNA Design
Reply #1 - May 23rd, 2011, 12:40pm
Chris2312,
The noise for the cascode stage will be degenerated by the output impedance of common emitter stage.  With that said size the cascode to operate at peak ft, then check the noise contribution, if negligible then stop otherwise increase the size until the tradeoff of bandwidth and noise is acceptable.
http://rfcooltools.com
vp1953
Re: LNA Design
Reply #2 - May 24th, 2011, 10:14am
Hi Chris 2312
I do not think LNA's operate like Class A power amps. Even before you get to zero current (due a large RF signal), there are some many issues relating to nonlinearity etc that prevent typical usage at high input power levels. There are some good examples in Tom Lee's book (most of which you can read online). Rfcooltools has provided a good summary of what needs to be done to reach noise-gain targets
purplewolf
Re: LNA Design
Reply #3 - May 28th, 2011, 2:21pm
@rfcooltools.com
 can you tell whats the simulation setup in spectre to determine the peak ft. Is peak ft dependent on demensions of device or only technology?
Secondly, i think the problem with increasing the size of common gate device would compromise the noise performance much more severe than bandwidth as the output impedance mismatch between common collector and common gate of cascode provides the best decoupling between input and output by minimizing effect.
@vp1953 If LNA is operated as class-B or class-C would create lots of harmonic contents. So, i think biasing should be in class A or worst case class AB
Re: LNA Design
Reply #4 - May 28th, 2011, 6:03pm
RF front ends are not a good place to have  learning experiences in IC design.
If it is for any typical RF front end, it is going to have to have a Class A structure to meet linearity requirements.
Do you have:
Noise spec
Linearity Spec
BW spec
Gain Spec
defined source impedance
defined output load
min max criteria on all, IP2, IP3 specs for linearity?
thats some of the very basic stuff you need before you get started.
vp1953
Re: LNA Design
Reply #5 - May 30th, 2011, 5:54pm
Hi Purplewolf,
LNA is only in Class A, I dont think it ever operates in class A-B. Even here operation is in the small signal regime unlike power amps where it is predominantly large signal operation.
You can find some good tutorials at
http://www.odyseus.nildram.co.uk/RFIC_Circuits_Page.htm
Tom Lee's book also has some good design examples.
Re: LNA Design
Reply #6 - May 30th, 2011, 5:57pm
vp1953 wrote on May 30th, 2011, 5:54pm:
Hi Purplewolf,
Almost always Class A for linearity - Never say never!
purplewolf
Re: LNA Design
Reply #7 - May 31st, 2011, 7:30am
Thanks vp1953 and loose-electron.. i got the point
rfcooltools.com
Re: LNA Design
Reply #8 - May 31st, 2011, 12:13pm
purplewolf,
many bjt foundries provide the peak ft as a component display parameter after running a DC operating point. Additionally ft can be approximated as gm/((Cbe+Cbc)*2*pi).
