Aug 29th, 2024, 7:15pm
Diode Connected BJT: Current Eqn:: a fundamental doubt (Read 8785 times)
ipsc
India
May 26th, 2011, 11:24am
The current for a diode connected BJT (base & collector shorted) is given by
I = Is * exp(qVBE/kT)
Now, my doubt is: what is ‘I’ here – IE or IC?
My intuition is that, it has to be ‘IE’ because above eqn is similar to a normal diode eqn and the diode here is VBE. And moreover, IC is a secondary form of this diode current.
It would be great, if someone can please clarify whether it is 'IE' or 'IC' and why (if possible with a reference)?
Re: Diode Connected BJT: Current Eqn:: a fundamental doubt
Reply #1 - May 28th, 2011, 6:14pm
Its a scalar for the current that is proprotional to the diode geometry - Dig out a copy of Grey and Meyer (or newer variant has more authors these days) and its all explained in there.
Treat it as Id and don't think like its a transistor anymore.
Or treat it like its a bipolar, and that Vbase = Vcollector and you are done.
Both are valid approaches
Considering how high beta is, is it really important anyhow?
raja.cedt
Reply #2 - May 29th, 2011, 6:49pm
hi,
it is Ic only, just derive from device physics basics. I didn't understand your intuition. Again i will go with loose-electron, when you have higher beta (typically that is the case), more or less it doesn't matter.
Thanks.
ipsc
India
Reply #3 - May 30th, 2011, 3:41am
Thanks loose-electron & raja.cedt for your replies.
@loose-electron
If I treat this way i.e. if I reduce BJT to two terminals:
  • Termial1 = Emittor
  • Termial2 = Collector + Base
Hence the diode current 'Id' becomes
Id = IE = IC+IB = Is * exp(qVBE/kT)
please correct me if I am wrong.
@ raja.cedt
sir, i am bit out of touch with the device physics. Could you please explain it to me conceptually/intuitively or at least methodology of derivation in brief?
But for CMOS technologies 'beta' is only in single digits, right?
ipsc
boe
Reply #4 - May 30th, 2011, 8:04am
ipsc wrote on May 30th, 2011, 3:41am:
For the parasitic pnp in modern technology nodes, yes.
B O E
raja.cedt
Reply #5 - May 30th, 2011, 9:16am
agree, for parasitic pnp diode beta is lesser in that case you should use IC rather than IE.
Thanks.
Reply #6 - May 30th, 2011, 6:07pm
If it is a good quality bipolar, Beta is on the order of 100 (YMMV) (a horizontal NPN with a thin base well structure)
If it is the collector tied to substrate PNP associated with a lot of CMOS then its Beta is around 6 to 20 (YMMV) this is a lateral PNP
You asked about bipolars and all of a sudden the question turns to parasitic PNP's on CMOS?
ipsc
India
Reply #7 - May 31st, 2011, 10:55pm
oops... Considering the generic nature of the Question, I didn't expect that not mentioning about parasitic pnp will cause so much confusion.
Let me also put in my main objective for asking this question. I am just trying to understand effects of BJT beta on a CMOS Bandgap. Hope everything is clear now !!!
Now coming back to my original question,
if I treat diode connected (B & C shorted) BJT as a diode and reduce it to two terminals, I will have:
Termial1 = Emittor
Hence the diode current 'Id' becomes:
i.e. in the diode connected BJT current eqn,
I is represented by IE not IC.
But as per raja.cedt it should be IC, if we derive the eqn from device physics basics.
Now, the question is where am I going wrong in my analysis?
ipsc
boe
Reply #8 - Jun 1st, 2011, 12:51am
Ipsc,
Since IB = IC/β, Id = IE = IC + IB = (1+1/β)*IC. Therefore, IE = Is1*exp(qVBE/kT), with Is1 =  (1+1/β)*Is.
B O E
Lex
Eindhoven, Holland
Reply #9 - Jun 1st, 2011, 1:48am
loose-electron wrote on May 28th, 2011, 6:14pm:
Well, you are less effected by the variations on Rb, which is nice.
Reply #10 - Jun 4th, 2011, 1:51pm
The equations you are going back to are "academic simplifications" - good for illustration of concepts.
However, I would not design a circuit based upon them.
Take the foundry provided models and work with those. If you want bias curves, take the foundry models and do a DC sweep curve set.
