This doesn't belong in this forum area; "Circuit Simulators" might be more appropriate.
I'm surprised not to see export LD_LIBRARY_PATH= somewhere, with some good paths after the =.
This might help it find libgfortran.so.1: export LD_LIBRARY_PATH=/eda/ius82/tools/lib
But if you set that, then you will likely find that there are other library files it can't find, that are in the default LD_LIBRARY_PATH.
