AmiyaB
Kolkata
I am using ipcBeginProcess(), to invoke command si(), to generate netlist. While netlisting, in CIW, i am getting "waiting for ipc:0 to terminate". Sometimes it shows ipc:0,1,2.....
Below is the part of the code : ================================ simPath=./sim/ WrkDir = . printf("--- Netlisting Starts\n") cid = ipcBeginProcess(strcat("si " simPath " -cdslib " WrkDir "/cds.lib -batch -command nl") "" "" "" "" strcat(simPath "/MyLog/netlistLog")) ipcWait(cid) printf("--- Netlisting Ends\n") ======================================
The code prints "--- Netlisting Starts" in CIW. Then it prints "waiting for ipc:0 to terminate" repeatedly for some 4 to 10 times, either until netlist is done or exit the process.
I am not sure about the network configuration. I am attaching the "/etc/hosts" file and "ifconfig -a" result :
=== /etc/hosts === 127.0.0.1 localhost.localdomain localhost ---> My machine ::1 localhost6.localdomain6 localhost6 192.168.1.100 homeServer
================= [root@localhost ~]# ifconfig -a eth0 Link encap:Ethernet HWaddr F0:4D:A2:EC:3B:3C inet addr:192.168.4.139 Bcast:192.168.4.255 Mask:255.255.255.0 ---> My IP address inet6 addr: fe80::f24d:a2ff:feec:3b3c/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 ====================
Can anybody give some idea how to solve it?
Regd, Amiya
