Oct 12th, 2024, 10:00am
PLL BW correlation (Read 4013 times)
raja.cedt
PLL BW correlation
Jun 01st, 2011, 2:59am
I am designing a PLL for for DDR-3 purpose. Target frequency was 1.6G. Through behavior simulations i adjusted LBW 4Meg. But could you please tell me is there any way to correlate bandwidth with transient simulations. I tried many ways like finding settling time of the control voltage or o/p frequency to some %ge of PPM, but unable to correlate.
finally does any one in industry do this?
Thanks.
Re: PLL BW correlation
Reply #1 - Jun 4th, 2011, 1:56pm
After you have the gain factors for all the PLL parts, you can do the basic math of the 2nd order control system model. From there - the voltage characterisitics on the loop filter is the next way to get things like the loop BW.
lwjee
Reply #2 - Jun 4th, 2011, 10:50pm
"Design of CMOS Adaptive-Bandwidth PLL/DLLs:
A General Approach" may tell you something.
raja.cedt
Reply #3 - Jun 4th, 2011, 11:16pm
hi loose elctron,
thanks for reply, after ding that math only i have started implementation, but now i want to correlate that with transient sim.
Thanks.
supermoment
Reply #4 - Jun 6th, 2011, 8:12am
you could extract wn & damping factor. after that you could get the BW by calculation.
or else you could use pll pull-in process to estimate the BW in transient simulation.
Reply #5 - Jun 7th, 2011, 5:42pm
Time domain responses of the voltage at the filter will show both zeta (damping) and Wo (loop bw)
Get the simulation in steady state mode, and then apply a phase or frequency step to the input and watch the charge pump and phase detector do their thing.
You may want to develop behavioral modesl of the whole loop, it speeds the simulation process up.
