Jul 16th, 2024, 11:31pm
Explanation Needed on these topics (Read 3648 times)
engineer
Jun 16th, 2011, 12:05am
1) Why both K and B1 are needed for amplifier stability
2) Difference between normal and gummel poon bjt
buddypoor
Bremen, Germany
Re: Explanation Needed on these topics
Reply #1 - Jun 16th, 2011, 3:44am
engineer wrote on Jun 16th, 2011, 12:05am:
Excuse me, but do you really believe that somebody can answer such a "question"? (K could be the Boltzmann constant and B, for example, the magnetic flux density)
fonseca.ha
UK
Reply #2 - Jun 16th, 2011, 6:11am
Hello Engineer
What do you mean by K and B?
H.
rfcooltools.com
Reply #3 - Jun 16th, 2011, 9:15am
Engineer,
The following link depicts the equations for the parameters you are discussing.
http://cp.literature.agilent.com/litweb/pdf/5989-9308EN.pdf
The way I would interpret it is that K can be less than 1 and still be stable so that is where B1 comes into the picture.  B1 >0 is similar to |delta|^2 <1 which qualitatively means that the reverse isolation is greater then the forward gain independent of matching.  Satisfying B1>1 or |delta|^2 <1 when K<1 implies stability.
http://rfcooltools.com
engineer
Reply #4 - Jun 16th, 2011, 12:27pm
Hello Folks,
what I mean by K and B1 is
K- Rollet Stability factor
B1 - Auxialary Stability Factor
In almost all books, the say thay for an amplifer to be stable, K>1 and B1 > 0.
I just want to know, why that both quantities are needed. Is K alone not sufficient ? Kindly explain.  Also, Can we leave K and consider only B1.
Engineer
rfcooltools.com
Reply #5 - Jun 16th, 2011, 7:16pm
Engineer,
Disregard my previous post where I stated that k<1 provided that B1>0 that is not unconditional.
Equations:
B1 = 1+|s11|^2 –|s22|^2 –|Δ|^2
K=(1–|s11|^2 –|s22|^2 +|Δ|^2)/(2|s12 •s21|)
|Δ| = |s11 • s22 – s12 • s21|
if |Δ|>1 then  |s11 | could be> 1 and the there are some cases where k>1 and its potentially unstable since the reflected voltage in port1 is greater then the transmitted indicating a negative real impedance.  i believe B1 >0 alone is not sufficient.  Its clear to me why |Δ|<1 K>1 are stable but it not obvious about K >1 and B>0.
