The only time I have seen this happen is when you have very large signals elsewhere in the circuit, which causes Spectre to not honor the time step control required by the source because its signal level is 'insignificant'. To avoid this, either get rid of the large signal, which often results from a current source driving an open circuit, or set the transient option relref to alllocal.
