Aug 30th, 2024, 5:21am
gain_margin (Read 2447 times)
vijayakumar.M
tamilnadu , INDIA
gain_margin
Jun 29th, 2011, 8:50pm
why we are getting gain margin at a phase of 0 degree instead of -180 degree?????
raja.cedt
Re: gain_margin
Reply #1 - Jun 29th, 2011, 9:19pm
hi,
The main motivation behind this gain margin is "if at all system goes into +ve feedback region it shouldn't have loop gain so that it won't do any harm to us". Now coming to your question when phase becomes -180deg system will be in +ve fB mode so check there how much loopgain below zero.
Thanks.
Raj.
buddypoor
Bremen, Germany
Re: gain_margin
Reply #2 - Jun 30th, 2011, 12:37am
vijayakumar.M wrote on Jun 29th, 2011, 8:50pm:
The answer to your question is simple:
Some authors plot the BODE diagram for the product gain*feedback (without consideration of the minus sign at the summing point) and some other plot the BODE diagram for the complete loop gain (including the sign inversion).
In the first case, the phase starts at zero deg and the gain margin is defined for a phase shift of -180 deg. (knowing that additional -180 deg have to be considered).
In the 2nd case, the phase starts at -180 deg (a "must" for negative feedback) and the gain margin is defined for -180-180=-360=0 deg.
I prefer the second case as it is based on the real loop gain (and is more logical, for my opinion).
Frank Wiedmann
Munich, Germany
Re: gain_margin
Reply #3 - Jun 30th, 2011, 5:20am
buddypoor
Bremen, Germany
Re: gain_margin
Reply #4 - Jun 30th, 2011, 8:43am
By the way: Both alternatives (loop gain T(s) or -T(s)) can be observed also in Nyquist plots. In some books/publications the "critical point" is located at "-1" and in some others at "+1" .
