chris2312
Yes I studied some papers about this topic. There are some possibilities to realize it. First, you design a broadband amplifier. Second, you design an amplifier with a switchable matching network and third is you design an amplifier where your matching network works well for two frequencies. In the last case you could not calculate the matching network because the input impedance of the transistor is changing for the two frequencies of interest, so you couldn't calculate it. Has somebody an idea, how i could calculate it ?
