Jul 21st, 2024, 12:20pm
Simulink Scope Viewer Blanks at Simulation End (Read 4579 times)
Jul 11th, 2011, 4:52pm
Using Matlab Simulink version R2011A, Version 7.7, March 9, 2011 version of SW.
I can set up and run a Simulink solution, however, when the simulation run hits the end time, the Floating Scope display blanks out.
You see the traces display, and then at simulation end, the scope viewer screen goes blank except for a small snip at the end of the simulation.
Probably something very basic, and stupid.
Any ideas? Thanks!
Re: Simulink Scope Viewer Blanks at Simulation End
Reply #1 - Jul 12th, 2011, 12:51pm
Floating scope does not retain data, the regular scope function does.
Problem solved
