Aug 16th, 2024, 5:03pm
"bandwidth" calculation (Read 7912 times)
wave
Jul 11th, 2011, 4:54pm
Hello - I have a bandpass filter, simulated with an AC response.
I'm using Cadence IC615, and in the calculator trying to get the -3dB points for both HPF and LPF corners.
It's a very clean filter passband (no ripples), and clean roll-offs (no P-Z doublets, etc.)
The AC sim is done well before the HPF corner and well *after* the LPF -3dB corner.
The calculator either
a) gives me an Error \n, does not evaluate waveform,
or
b) calculates one side (ie, low or high), but gives a very wrong result.
Any tricks??
thanks,
Wave
Huh
wave
Re: "bandwidth" calculation
Reply #1 - Jul 12th, 2011, 1:26pm
In case more detail helps, the Calc function is:
bandwidth(dB20(VF("/sim_node2")) 3 "low")
kokabanga
Reply #2 - Jul 13th, 2011, 8:40am
bandwidth(VF("/sim_node2") 3 "low")
naren
wave
Reply #3 - Aug 29th, 2011, 2:51pm
I finally looked at this again.
I think the issue is I have a BandPass response (HPF + LPF).
So "high" and "low" (pass filters) key off of the DC gain, which doesn't exist.
There is a "pass" function that measured the LPF-HPF 3dB point;
However, that tells me the BW between the points, not what Frequency the points are at.
I really need to:
measure MAX passband gain.
Then measure -3dB at a Higher Freq from Max frequency.
Then measure -3dB at a Lower Freq. from Max frequency.
Reply #4 - Oct 9th, 2011, 2:08am
Wave,
  For what it is worth bandwidth works for me.
