Aug 16th, 2024, 11:30am
input impedance of RLC tank, and characteristic impedance (Read 1457 times)
dxt78
Ohio
Jul 14th, 2011, 8:42am
I have an RLC tank as shown in attachment (2R in parallel with an L and a C).  I have two questions about it:
1) Why is the characteristic impedance of this LC tank sqrt(L/C) and what meaning does it have?
2) When computing the input resistance of this tank, what role should the characteristic impedance play?
Thanks.
buddypoor
Bremen, Germany
Re: input impedance of RLC tank, and characteristic impedance
Reply #1 - Jul 14th, 2011, 8:57am
There is one single frequency wo=1/sqrt(LC) for which the reactive conductance of the capacitor and of the inductor (wC and 1/wL), respectively, are equal.
That means, at w=wo the input impedance of the whole circuit is zero.
Now the answer to your question:
If woC=1/woL you can insert the above expression for wo and you get:
woC=sqrt(C/L)   and  woL=sqrt(L/C).
In words: The characteristic impedance is the impedance of both reactive elements for w=wo (resonant frequency).
RFICDUDE
Reply #2 - Jul 14th, 2011, 7:08pm
Your tank circuit is not 100% realistic. It is not physical to have two ideal reactive components in series and then a loss in parallel with the series LC; although, maybe this is a practical equivalent that I have not considered before.
A tank is usually a parallel RLC or a completely series RLC. The circuit you present is a perfect short at f = 2*pi/sqrt(LC).
The characteristic impedance represents the lossless energy exchange between C and L while R should represent the power dissipation.
The characteristic impedance should not necessarily be tied directly to the resistance, but it may be indirectly related if the source of the resistance is the series resistance in the inductor.
Others can correct me if my interpretation is not the best for your question.
raja.cedt
Reply #3 - Jul 14th, 2011, 9:03pm
hello dxt78,
as RF id said it's not a tank circuit. General meaning of tank is LC parallel circuit which can give pure sinusoidal osculations @ 1/sqrt(LC). i guess here you drawn ckt wrongly i guess. When you wish to add loss into tank generally series with inductor and seris with capacitor  is good model. but here you have drawn LC seris circuit and then it has 2k // res. This ckt don't have any practical usage.
If you just want to know whats the characteristic impedance of your circuit, it is the frequency at which you will see 0 volts impedance
Thanks.
rfcooltools.com
Reply #4 - Jul 18th, 2011, 12:12pm
dxt78,
By use of the term "characteristic impedance" I  assume that you mean "transmission line characteristic impedance".  For simplicity  ignore the 2R in your circuit because when connected the impedance is not sqrt(L/C) Im going to ignore it and show how a lossless t-line will result in the sqrt(L/C).  For this tline picture that you place a port at the left hand side L and another connected to the node that ties the L and C together.
For an ideal transmission line with ideal source/load impedance Zout=Zin = Z0
Vin/(sL+Z0||1/sC) =  Vout/(sL+Z0)
Iin*((1/sC)||Z0)=Iout*((1/sC)||(sL+Zo))
Vin/In = Vout/iout = Z0
Solve for Z0 and it will equal sqrt(L/C)
http://rfcooltools.com
Larry_80
Reply #5 - Jul 19th, 2011, 10:20pm
This is in response to people suggesting the circuit is not a "realistic" tank circuit in RF. I completely disagree with this. A monolithic inductor can have a series parasitic capacitor associated with it and a parallel parasitic resistor depending on how the parasitic cap and resistors are modeled.
purplewolf
Reply #6 - Jul 21st, 2011, 6:15am
infact the series LC structures are claaed harmonic traps rather than harmonic tanks.
harpoon
Hampshire
Reply #7 - Jul 25th, 2011, 3:51pm
dxt78,
What are you trying to achieve with this circuit of yours ? I presume it is a RF trap with some matching/loading ?
