Sep 9th, 2024, 7:16am
a ridiculous 'overshoot' (Read 4722 times)
chaojixin
Shanghai
Jul 26th, 2011, 6:43pm
I encounter a ridiculous 'overshoot' in a PGA design as shown in (B) which is  is quite different from the normal overshoot as shown in (C). the phase margin is enough (80 degree), and the opamp is a cascode + gain-boost structure. but when I reduce the W/L of input MOS pair and keep bias current  unchanged, the response of Vo becomes normal as shown in (D).
what does this ridiculous 'overshoot' come from? is it something to do with the parameter setting of input MOS pair?
thanks!
View Profile chaojixin chaojixin 278916917   IP Logged
Lex
Eindhoven, Holland
Re: a ridiculous 'overshoot'
Reply #1 - Jul 27th, 2011, 2:37am
First of all, let me ask u whether your transient repsonses are small signal, or large signal. For large signals, you might get some slewing effect in the way. If you simulated a small signal, I think this kind of overshoot should be predictable by AC analysis.
RobG
Bozeman, MT
Reply #2 - Jul 27th, 2011, 4:29pm
That looks like a zero in the transfer function not being cancelled exactly by a pole (i.e. a pole/zero doublet).
chaojixin
Shanghai
Reply #3 - Jul 27th, 2011, 10:51pm
I forgot something: it is large signal response. the ridiculous 'overshoot' is only several mV and its location is very closed to steady state value. but it did slow down the setting up
chaojixin wrote on Jul 26th, 2011, 6:43pm:
thanks!
wave
Reply #4 - Jul 28th, 2011, 1:18pm
What "large signal" amplitude are you putting in?
It could be you are slewing most of the way and small signal is not relevant.
Reply #5 - Aug 4th, 2011, 7:55am
It can also be a transient from input to output capacitively coupling thru the transistors.
If you are trying a "step response" you will see the step couple through system.
