Did you try running the netlist given in that PDF as Listing 1?
I would expect you to see a non-zero std dev there. If you get 0, then you probably should re-read that document and try again.
I'll assume for now that you get non-zero for that example, and now you're trying to do something else. Do you have a foundry model file, and you want to add statistics to their models (which don't have them)? Or are there statistics blocks in the model file, and you don't know how to make a netlist that makes use of them?
