Aug 16th, 2024, 12:19am
Using transient simulation to predict jitter (Read 4207 times)
YCY
Jul 30th, 2011, 6:39pm
Hi Frank
I read your post in previous thread
http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785/25#25
You mentioned that jitter could be analyzed using transient noise,
and it has a good matching with that of pnoise.
I don't know how to calculate jitter using transient simulation,
because in the eyeDiagram, Ican only see the peak-to-peak jitter.
I have no idea how to get the rms value.
Could you please provide more information about how to do this?
Thanks a lot.
regards,
YCY
Re: Using transient simulation to predict jitter
Reply #1 - Aug 1st, 2011, 4:24am
YCY,
  You don't specify what you are looking for, if you are looking
at jitter of a clock signal in Virtuoso, then try using the calculator
rms( period_jitter(Vsig) - avg( period_jitter(Vsig))
YCY
Reply #2 - Aug 1st, 2011, 7:28pm
Hi, Sheldon
Thanks for your reply.
I just wonder how to use transient simulation to find out jitter.
For example, if I connect a chain of inverters and apply a clock signal at input,
then how do I get the edge-to-edge jitter using transient simulation?
Frank mentioned that one can use eyeDiagram function in the calculator to do so,
and I am curious how to do that.
BTW, you said I can use "rms( period_jitter(Vsig) - avg( "period_jitter(Vsig)) in the calculator.
Is period_jitter() a calculator function?
I cannot find that in the calculator in Spectre.
regards,
YCY
Reply #3 - Aug 7th, 2011, 5:21am
Hi YCY,
period_jitter is a function in calculator for VIVA. VIVA is available if you have IC6.x.
However, period_jitter is not present in wavescan.
Yawei
YCY
Reply #4 - Aug 8th, 2011, 9:43pm
ywguo wrote on Aug 7th, 2011, 5:21am:
Hi YCY,
Yawei
Hi, Yawei
Thanks for your response.
No wonder I cannot find it in my calculator (I use IC5141).
Nonetheless, I am still curious about how to get jitter using eyeDiagram().
Does anybody know how to do that?
regards,
YCY
