Dec 17th, 2025, 5:13am
try to read a file (Read 15365 times)
sunnysunnyho
try to read a file
Aug 02nd, 2011, 7:48am
Hi.
I am trying to read a file from my verilog-AMS program (.csv, it is a lookup table with 2 lists of arrays).
real code[41:0];
real thresh[41:0];
initial begin
     openfile = $fopen("file", "rb");
     readfile = $fscanf("file", "%g %g\n",code[40:0],thresh[40:0]);
ncvlog: *E,NOPSOM file,33|72): Part-select or indexed part-select cannot be applied to memory [4.2.2(IEEE)].
ncvlog: *E,NOPSOM (file,33|85): Part-select or indexed part-select cannot be applied to memory [4.2.2(IEEE)].
     module testlib.adcdiscrete:verilogams
The $fopen part of the codes is OK. The syntax/s of the $fscanf function is the same as the one in the manual.
I have no idea what's going on Sad Embarrassed
Re: try to read a file
Reply #1 - Aug 2nd, 2011, 9:17am
My guess is that you cannot use a range of indices on a real vector. Perhaps if you rewrite the code by adding a for loop so that you only access one value in the array at a time.
sunnysunnyho
Reply #2 - Aug 3rd, 2011, 2:23am
It is still not working Sad
To try to solve the problem/s I created a program which just open, write and read a .txt file.
module readfile ( );
integer file;
integer readfile;
integer code;
integer a;
initial begin
     a=999;
     file = $fopen("/home/sunny/Desktop/loadfile/testing.txt", "rw");
     $strobe("\nfile OK? = %d\n", file);
       $fwrite(file, "%g", a);
     readfile = $fscanf(file, "%d\n", code);
     $strobe("readfile OK?=%d", readfile);
     $strobe("code = %d\n", code);
I can open and write to the file (it shows '999' in the .txt), but I cannot read from the file, in fact, the variable readfile returned as "-1" and the code returned as "x".
Reply #3 - Aug 3rd, 2011, 5:00am
I would expect you to need to close and re-open the file in order to read it.  Or, at least, you'd need to "rewind" it (is there an $frewind?), because after writing, the file handle will point to the end of the file, and that's why you're getting an EOF error when you try to read.
sunnysunnyho
Reply #4 - Aug 4th, 2011, 2:38am
Thank you very much for your help, guys!!
