Jul 15th, 2024, 11:21pm
Variable number of components (Read 4845 times)
transconductance
Aug 03rd, 2011, 12:14am
Hello, i am new to this forum. I hope this is the right section to put my question in.
I would like to make a model with a variable number of components.(passives like resistors or diodes)
The number should be programmable by the component menu.
The components should be connected in series.
Is there an easy way to do this?
Thanks a lot
tr
DDC
Re: Variable number of components
Reply #1 - Feb 3rd, 2012, 12:44am
If you only do static analysis you can use switches.
boe
Reply #2 - Feb 3rd, 2012, 7:26am
Transconductance,
tool? language?
If Verilog-A is OK for you, see e.g. this thread: http://www.designers-guide.org/Forum/YaBB.pl?num=1328123432
- B O E
