Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 16
th
, 2024, 1:19pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› sizing differential pair transitors
Previous topic
Next topic
sizing differential pair transitors (Read 7143 times)
purplewolf
Aug 04
th
, 2011, 4:31am
I simulated a differential pair with ideal tail current source from 500uA-3mA The width of diff pair transistory were kept contact to 12u in 180 nm CMOS. I found out that the circuit gives good performance at 1.4mA. The next task would be replace the ideal current source with current mirror. But how do i size the diff pair transistors. Is 12u width enough for 1.4 mA tail current...The Spectre does not give me anysort of error. whats the tradeoffs and am i missing something.??..
IP Logged
Lex
Eindhoven, Holland
Re: sizing differential pair transitors
Reply #1 -
Aug 4
th
, 2011, 5:06am
The current density doesn't looks very extreme, so I think you'll be fine. Check your PDK doc's for confirmation.
Needless to say, watch your layout to avoid limitations by Ohmic drops, or even in worst case, burning metal tracks. ><
IP Logged
purplewolf
Reply #2 -
Aug 4
th
, 2011, 5:34am
I want to understand the relation between tail current transsitor W/L and the diff pair transistor W/L.. Since, when the diff pair transistor is fully on, Itail will flow through it. Why not make it equal to Itail device?? But it will have huge parasitic capacitance associated with it!! Whats the criteria of sizing diff pair device so that its dimension is optimum and robust and will work in all environments..
IP Logged
Reply #3 -
Aug 4
th
, 2011, 5:53am
simple questions:
Where are the transistors functioning on a set of bias curves?
What is the optimal matching geometry for the process?
Have you done the differential pair with a set of M=2 transistors, so that you can common centroid the differential pair in the layout?
IP Logged
purplewolf
Reply #4 -
Aug 4
th
, 2011, 6:10am
loose-electron wrote
on Aug 4
th
, 2011, 5:53am:
simple questions:
The diff pair is a part of charge pump which will get input from PFD. How do i get its functioning from set of bias curves as you are mentioning.
I dont know about this
I have multiplier factor of 2. But what about its width and length adjustment. What is i choose other multiplier factor
IP Logged
purplewolf
Reply #5 -
Aug 4
th
, 2011, 6:11am
Repost.
simple questions:
ANSWER:The diff pair is a part of charge pump which will get input from PFD. How do i get its functioning from set of bias curves as you are mentioning.
ANSWER:I dont know about this
ANSWER: I have multiplier factor of 2. But what about its width and length adjustment. What is i choose other multiplier factor
IP Logged
Reply #6 -
Aug 4
th
, 2011, 7:49am
That is not a differential pair, as in the input of an op-amp. What you are describing is a set of current steering switches, in an H-bridge configuration.
Different considerations for that. Minimum geometry for devices, at the weakest process corner and the most expected current in the devices. That gets you to the smallest sized device to steer current.
For this application, the reason you are trying to get to the smallest devices is so that you minimize charge injection into the loop filter.
IP Logged
purplewolf
Reply #7 -
Aug 5
th
, 2011, 2:34am
The peak current that passes though the current steering switches is equal to Itail. If the size of tail current device is 100u and the size of steering device is 12u, will there be any physical reliability issues on part of steering device due to its smaller size and more current passing through it?
The physical reliability issues can be adressed through weakest process corner??
Am i thinking in right direction??.
IP Logged
Reply #8 -
Aug 6
th
, 2011, 11:21am
look thru your foundry data for information available on max current vs. device size. Might be with the electromigration stuff, but this is something different.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
