Aug 3rd, 2024, 1:13am
Frequency to voltage conveter using digital gates (Read 2115 times)
Faiq Khalid Lodhi
Islamabad
Aug 05th, 2011, 3:05am
hi every one
can any tell me that how can i convert the frequency into the voltage by using the digital gates only.
Faiq Khalid Lodhi
Electronics Engineer
NUST Pakistan
View Profile Faiq Khalid Lodhi fklodhi1989   IP Logged
raja.cedt
Re: Frequency to voltage conveter using digital gates
Reply #1 - Aug 5th, 2011, 5:26am
you should have some other reference clock, otherwise how frequency wil be detected by only digital gates?
Thanks.
Reply #2 - Aug 6th, 2011, 11:51am
Frequency into voltage using digital gates only?
Digital gates don't produce a proportional voltage output, so the question seems a bit flawed.
With a reference clock of some form, you can use counters to determine number of cycles for a defined period of time. That gets you a number that indicates frequency.
With that, you can create a DAC structure that outputs a proportional voltage. A PWM DAC can be made with logic gates mostly, and a LPF.
