![](https://designers-guide.org/forum/avatars/fredflinstone.gif)
Best Design Tool = Capable Designers
Frequency into voltage using digital gates only?
Digital gates don't produce a proportional voltage output, so the question seems a bit flawed.
With a reference clock of some form, you can use counters to determine number of cycles for a defined period of time. That gets you a number that indicates frequency.
With that, you can create a DAC structure that outputs a proportional voltage. A PWM DAC can be made with logic gates mostly, and a LPF.
