Aug 31st, 2024, 7:18pm
Where does the skin effect in inductors cause the most pain? (Read 4968 times)
tonyc
Aug 07th, 2011, 5:12pm
I know it's an issue at RF, but does anyone know if there are other applications where it imposes practical limitations?
PS: This is a great site, Kens work is impressive.
raja.cedt
Re: Where does the skin effect in inductors cause the most pain?
Reply #1 - Aug 8th, 2011, 1:04am
be clear man while asking...''Where does mean''. In what frequency regime or in which application or...etc
Thanks.
Lex
Eindhoven, Holland
Reply #2 - Aug 8th, 2011, 2:20am
Skin effects are also quite important in the design of mains 50/60 Hz electrical power distribution. I suggest you at least read the wiki page or use google?
tonyc
Reply #3 - Aug 8th, 2011, 1:55pm
Thanks for the replies and my apologies for not being clearer.
Yes, I am looking for applications where skin effect imposes a practical limit on circuit performance. What do I mean by "practical"?
As a hypothetical example, let's imagine the reduction in the Q of an inductor (due to skin effect) sets a maximum frequency of an oscillator due to increased phase noise. This "problem" is solved by using a different type of oscillator.
Why do I care about such things? Well, I have a solution for reducing the skin effect. It increases the complexity of a circuit of course. This increase in complexity means it's only an attractive solution (commercially) when it presents more benefit than the alternative does to circuit designers.
aaron_do
Reply #4 - Aug 8th, 2011, 6:51pm
Hi tonyc,
skin effect is a huge problem. It directly translates to power loss, which degrades efficiency and output power in transmitter PAs, and leads to poorer achievable NF in receivers.
In terms of practical limits, I'm don't know of any, but they definitely exist. They may be very structure/technology dependent, and so maybe you need to treat them on a case by case basis.
Good luck with your idea.
regards,
Aaron
RFICDUDE
Reply #5 - Aug 10th, 2011, 5:04pm
Skin effect is important to different applications. As mentioned, any AC power application where the conductor thickness is thicker than the skin depth will suffer from skin effect losses.
In integrated RF circuits, the conductor thicknesses tend to be on the order of the skin depth, so it is debatable whether or not it is worthwhile to mitigate skin effect losses on chip.
Off-chip applications/components with thick conductors may benefit the most from a technique that mitigates skin effect losses.
Coincidentally, I have been doing some hobby work with crystal radios lately and it is very interesting to note that skin effect dominates Q factor even at 1MHz! The solution at these frequencies is to use bundled insulated wires (Litz wire) where the diameter of each strand is less than the skin depth. This is a very good solution for fixed frequency applications, but the downside is that Litz wire is expensive.
tonyc
Reply #6 - Aug 11th, 2011, 6:01pm
Thanks RFICDUDE.
AC power apps are out, technical incompatibility.
RF power/lna IC apps are out for the reason you give.
YES to off-chip apps.
I googled Litz wire. The "induction cooker" app is very interesting, could be a very good fit.
I'd appreciate if you could explain in a little more detail why/how/where you use Litz wire in your crystal radio app. I don't know much about it. Is it a significant cost component to the radio? If no, why is it worth getting rid of?
RFICDUDE
Reply #7 - Aug 12th, 2011, 3:50am
Crystal radios directly convert RF power into intelligible audio power without use of amplifiers. Any power wasted in the RF components will directly reduce the available audio power of a received station.
Litz wire minimizes the losses in the wires used to make the inductor coils and sometimes the antennas.
Selectivity of the crystal radio is limited by the loaded Q of the tuning circuits. For broadcast band AM radio the stations are 10kHz apart in a band that that spans 0.5MHz to 1.6MHz. At 1.6MHz 10kHz 3dB bandwidth is a Q = 160. So you also want to maximize Q in the long wire inductors to prevent them from limiting the loaded Q of the tuning/matching circuits.
Also, Litz wire is widely used for cheap AM radio antennas. Almost any cheap AM radio has a ferrite bar antenna mounted inside the radio. There is usually some wire that looks like it has a reddish or pinkish coating wrapped around the bar. This wire is typically Litz because they can use a thinner Litz wire for the same loss as a thicker solid wire.
tonyc
Reply #8 - Aug 12th, 2011, 4:37pm
Crystal radios sound like fun but since they don't use power my solution isn't compatible. I wouldn't have stumbled across induction cookers if not for your reply RFICDUDE, so thanks! I'm not sure that app has enough "pain" with Litz wire for its developers to consider something different but I'll dig into it.
My solution was originally developed for optimizing high rate charge and discharge of batteries (also works great at low temps). It turned out that the perceived tradeoffs were too great so it never got adopted. Looking into it further led me here (this forum) as I began researching dielectric absorption in capacitors. Ken has a great  paper on that. But that "app" (high-res ADCs limited by DA in sampling caps) has already found alternative solutions that are now mature.
After reading another of Ken's papers, I learned my technique actually also applies to the skin effect (or more generally, any kind of phenomena that must be modeled by frac-poles). This is really nice on-line community for experienced designers to share ideas. I hope to contribute on the answer side in the future.
