Jul 17th, 2024, 9:19am
Class F Power amplifier with no offchip components (Read 1381 times)
vp1953
Aug 12th, 2011, 9:07am
I was wondering if it is possible to make a class F power amplifier with no off chip components at all. Most manufacturers spec show that off chip filtering is always required - example numbers are for 14dBm transmit power at 915M, with offchip filtering, the second harmonic is at -50dBm.
Any reference for a completely integrated Class F power amp would be appreciated.
Thank you.
