Apr 27th, 2024, 6:23pm
Measuring Gm in presence of offset (Read 7423 times)
rajdeep
UK
Aug 14th, 2011, 12:33pm
Hi All,
Can anybody tell me how one can measure in ATE gm of an OTA in presence of input referred offset Vos?
The easiest method I can think is that I apply a difference voltage V1 across the OTA and measure the output current Iout1 of it, then Iout1 = Gm(V1 - Vos) [assumed a - sign]. Then we apply V2 as the i/p diff voltage such that V2 has the same polarity as V1. Then Iout2 = Gm(V2 - Vos). Then Gm = (Iout1 - Iout2)/(V1 - V2).
Do you think it is correct? Can the input referred offset Vos change its
value during the 2 measurements as the operating point is changing?
Rajdeep
boe
Re: Measuring Gm in presence of offset
Reply #1 - Aug 15th, 2011, 10:06am
Rajdeep,
why not use small-signal analysis so you don't have to worry about changes in operating point?
B O E
rajdeep
UK
Reply #2 - Aug 15th, 2011, 11:33am
BOE,
Can you pls elaborate? I have never used any test methods that uses small-signal analysis in ATE.
Well in my post I should have mentioned that V1 and V2 should be small enough. The OTA has constant Gm for +-50mV. So I can safely use V1 = 10mV, and V2 = 15mV without really going out of the nice region where Gm is designed to be linear. This is assuming the offset is not that large to drive it out of the nice region. So in this case do you think this method will have any problem? I just dont like the fact that I am not trimming the offset first and measuring Gm in presence of it, although I cannot see any technical difficulty in this method. I am kind of happy and not!  :-/
Thnx!
Rajdeep
boe
Reply #3 - Aug 17th, 2011, 2:08am
Rajdeep,
Oh sorry, I didn't read your post accurately enough and overlooked the "ATE".
But in this case your method should be OK. I don't expect the offset to change much here.
B O E
rajdeep
UK
Reply #4 - Aug 17th, 2011, 3:41am
Ah! That's too bad! I was desperate to find out something bad about it, as before this I thought of a much more subtle (read complicated) way of doing this! But this is so darn easy Undecided
Anyway thanks for confirming this!
Rajdeep
nehaali
Reply #5 - Jun 16th, 2013, 9:43pm
Hi everyone,
It is really very nice and informative forum thanks for sharing ....
neha
