Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 2
nd
, 2024, 3:10pm
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› Tones in the spectrum of Sigma Delta Modulator
Previous topic
Next topic
Pages:
1
2
Tones in the spectrum of Sigma Delta Modulator (Read 11151 times)
jefkat
Re: Tones in the spectrum of Sigma Delta Modulator
Reply #15 -
Sep 19
th
, 2011, 7:08am
Input signal is 1.0V differential.
SNDR is 82dB.
An alternative to DEM is used
3rd order non linearity approximately 84dB below carrier...
IP Logged
harpoon
Hampshire
Reply #16 -
Sep 19
th
, 2011, 7:37am
may I ask what "alternative DEM" method you used ?
The results you posted are certainly respectable ...
what is the worse SNDR (sample to sample) did you see and what is the maximum bandwidth of your SD-ADC ?
in any case ... well done !
IP Logged
jefkat
Reply #17 -
Sep 19
th
, 2011, 9:03am
I would publish and let you know the technique
I yet have to do measurements to check variations
IP Logged
Pages:
1
2
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
