mix
I am currently experimenting with a DtoSE (differential to single ended) converter, and I would like to characterize its balance using the CMRR (Common mode rejection ratio) figure of merrit.
I would like to hear your opinion on the difference (is there one actually?) between the definitions of the CMRR (Common mode rejection ratio) in the analog and the RF worlds.
To be more specific, the classic analog definition of CMRR is |Adm/Acm|, where Adm is the differential voltage gain and Acm is the common mode one. Let's name S (single ended) the output port, P the positive input and N the negative one.
DtoSE pinout P-----| | | |--S N-----| |
If we simulate/calculate the single ended gains Asp (drive P port with N port ac shorted) and Asn, I believe we can use the following relations to find Adm, Acm and thus CMRR. Adm=(Asp-Asn)/2 Acm=Asp+Asn CMRR=|(Asp-Asn)/[2(Asp+Asn)]|
On the other hand, the definition of CMRR based on S-parameters is: (see e.g. MTT paper Combined Differential and Common-Mode Analysis of Power Splitters and Combiners)
CMRR=|Ssd/Ssc|=|(Ssp-Ssn)/(Ssp+Ssn)|
and that's because Ssd=(1/sqrt(2)) * (Ssp-Ssn) and Ssc=(1/sqrt(2)) * (Ssp+Ssn). where the symbols mean: Ssd: mixed mode S param, gain from diff input port to S output Ssc: mixed mode S param, gain from comm input port to S output Ssp: single ended S param, gain from P input to S output Ssn: single ended S param, gain from N input to S output
So, the same circuit, shows 6dB higher CMRR when it is S-parameters simulated with respect to an AC analysis.
Which is the correct one ?
Similar differences of 6dB between Sparam and Voltage gains can often rise due to improper port matching, and this is well understood. However, I believe this is not the case with the DtoSE.
It is worth noting that the amplitude imbalance i derive via simulation is the same in both domains i.e. |Asp/Asn| = |Ssp/Ssn| which further confuses me, and shows that the CMRR differences are probably due to different definitions. Is any of them "more correct" ?
So, my feeling is that you have to explicitly state which CMRR definition you are using CMRRanalog or CMRRrf. Do you agree with this?
Thank you for your time, Looking forward to your replies. mix
