weigiho
Austin
I try to simulate a switched-capacitor to find its equivalent resistance. The cap=1pF and the clock rate is 2GHz (rise=fall=1 psec), with non-overlapping phi_1 and phi_2. I run a PSS/PAC analysis with PAC magnitude=1 and then I measure the current flowing into the switch for side-band=0 (input=10KHz-10MHz). The theoretical resistance should be 1/fC=1/(2G*1pF)=500ohm, and hence the current at sideband-0 should be 2mA. However, I found
if PSS-number of harmonics=PAC-maximum sideband=10, the current is 1.13671mA.
if PSS-number of harmonics=PAC-maximum sideband=50, the current is 2.0625mA.
if PSS-number of harmonics=PAC-maximum sideband=100, the current is 2.035714mA.
However, if PSS-number of harmonics=PAC-maximum sideband=0 and PSS-time step parameters-maxstep=20fsec, the current is 2.0000mA.
I read the paper "Efficient AC and Noise Analysis of Two-Tone RF Circuits" section-2A, and have the following questions:
(1)Did this paper section-2A give the basic theory behind the PSS/PAC engine?
(2)If yes, why increasing the PAC-maximum sideband helps? it looks to me that what is needed is an accurate Vs(t) (in the paper), number of sidebands should not matter. Also, how can I set the hj=tj-tj-1 in the paper in the PSS/PAC engine?
(3)What does the "PSS-time step parameters-maxstep" do? Why set it to a small number helps? Is it when we set it to be small, we can get a more accurate matrix in eq(8) of the paper? And what is the general rule of setting it?
(4)Can you suggest some readings about methods of how to get the matrix in eq(8) in the PSS/PAC engine accurately?
Thanks very much!
