Aug 2nd, 2024, 7:19pm
fractal sequencing to cancel offset in delta sigma ADC (Read 5785 times)
singh
Sep 02nd, 2011, 7:40am
can some explain me how we can use fractal sequencing to nullify offset in second order delta sigma ADC?
thanks
vivkr
Re: fractal sequencing to cancel offset in delta sigma ADC
Reply #1 - Sep 5th, 2011, 5:45am
singh wrote on Sep 2nd, 2011, 7:40am:
thanks
why not look it up in the original reference which explains it fairly well if I recall correctly: JSSC, July '06, Quiquempox et. al. A Google search leads you straight to the paper:
www.mit.bme.hu/~markus/pubs/jssc2006.pdf
Vivek
singh
Reply #2 - Sep 6th, 2011, 7:23am
oh thanks...
how can we apply fractal sequencing method to mullify offset in the input signal...any idea?
it will be great if some one can provide me a brief matlab implementation for that as i m new to matlab.
singh
Reply #3 - Sep 7th, 2011, 7:22am
the link which u have given above is describing fractal sequencing.But how it is applied in the circuit (fig 5) of the paper.
please explain me briefly..it will be very helpful.
vivkr
Reply #4 - Sep 8th, 2011, 11:43pm
not quite sure what you want to know. Fig. 5 not only shows the exact manner in which you need to add the chopping switches, but also the fractal timing sequence to control those. I doubt if it is possible to explain it better in words.
Maybe you should try reading the paper a couple more times to get a grasp of it, or if you are not familiar with such circuits, then seek out a colleague of yours who is.
Vivek
singh
Reply #5 - Sep 9th, 2011, 5:35am
Thanks..
I have offset in my input signal due to previous stage and this input+offset is fed to integrator of sigma delta .Thus i need to compensate both the offsets.
So the same circuitary is applicable to nullify the total offset (due to input and due to integrator)?
I am a third year student in bachelors and i think i have taken a tough project.  :-/
vivkr
Reply #6 - Sep 12th, 2011, 1:53am
if you have an offset in your input signal, then this is now part of the signal itself. you cannot get rid of it using chopper stabilization or fractal sequencing. The whole idea behind all these methods is that you don't disturb the input signal and retain all of it including any DC component, but simply modulate the offset of the circuitry operating on the signal.
If you need to get rid of offset contained within the input, then you would need to so something else. The easiest thing that comes to my mind is to apply chopper stabilization or fractal sequencing to whatever circuit is providing your input signal in this case. I doubt if you can simply get rid of the offset by directly filtering it as you would then lose any low-frequency information contained in the signal, which in your case is likely to be relevant.
On a side note, maybe you have taken up a tough task, but you will probably gain more if you do pull it off. Ever heard of "no pain, no gain"?
Vivek
singh
Reply #7 - Sep 12th, 2011, 4:35am
Thanks vivek for your valuable suggestions
i referred on document
http://www.patentgenius.com/patent/6909388.html
this is the reference paper for the one u provided me for fractal sequencing.here they say that the approach is used to separate offset from the input signal (page 7)
before this sigma delta ADC, I am using an integrator which is setting an offset to my input signal to SD ADC.This offset is mainly due to feedback capacitor KT/C noise.
I was also thinking to give a shot applying fractal sequencing to this integrator block.
the offset due to KT/C is around 20 mV. Is it not possible to use the first stage of DS ADC integrator to nullify the offset. But point is like how the circuit will distinguish input offset value from Input signal as both (input+inp offset) will be stored in capacitor cin (fig 5 of paper ) and will be supplied as combined input to integrator phase of ADC?
regards
manjeet
« Last Edit: Sep 12th, 2011, 5:41am by singh »
vivkr
Reply #8 - Sep 13th, 2011, 5:48am
singh wrote on Sep 12th, 2011, 4:35am:
regards
manjeet
Manjeet,
There are several points to be made here:
1. As you correctly noticed, it is not possible to separate signal from offset once this "offset" is embedded into the signal, atleast not without removing the low-frequency part of the signal itself, which you don't want to do I suppose. But what you are talking about is anyway not offset. See point 2.
2. kT/C noise is not an offset. It is caused by sampling of wideband thermal noise. Also, you need to use metrics such as standard deviation to specify this noise. On a side note, I do hope that you do not have a standard deviation of 20 mV (given as sqrt(kT/C)), as that would be highly unlikely for most realistic values of C.
It seems to me that you are not yet familiar with concepts related to noise at the moment, which is understandable if you still an undergrad. But perhaps you want to talk to your professor and get his advice on how best to approach the problem at hand.
Vivek
