raja.cedt
hello, When you swap also it should oscilate at least at some frequency. may be you forgot to add some intial conditions for start-up, or when you swap the capacitance will change probably it will increase and there is lot of loss at the lower frequency so hence no oscilations.
So one check is swap and increase the current, you will see oscilations. as rfidea told you should always find the capacitance and resistance by using as AC simulations, add this to tank loss. However many times you will get more frequency in simulation compared to 1/(sqrt(LC)).
Thanks.
