raja.cedt
hello, it is very difficult to control gain, you wil get some which is strongly depends on the process, at the end of the day you need to put your opamp in -ve feedback, so probably you might have some gain spe based on steady state error. So first fully simulate this block and see how much gain you have, and then try to design 2nd stage with common Source. You can check razavi for bias control (make sure that 2nd stage bias current equal to half of the tail current in the first stage)
I feel his is more than enough for normal two stage opamp.
THnaks.
