Aug 31st, 2024, 11:51pm
help with simple multiplier (Read 3242 times)
samy
Sep 05th, 2011, 5:40am
the program is for a  simple multiplier using addition of the partial products. i find problem only with final addition part pls help me out
architecture Behavioral of new_twin1 is
type arr is array (3 downto 0) of std_logic_vector(3 downto 0);
type arr2 is array(4 downto 0) of std_logic_vector(7 downto 0);
signal and_1:arr:=("0000","0000","0000","0000");
signal t6:arr2:=("00000000","00000000","00000000","00000000","00000000");
signal temp:std_logic_vector(3 downto 0);
signal sum:std_logic_vector(7 downto 0):="00000000";
begin
process(clk)
variable z,t,k:integer;
variable t2:std_logic_vector(3 downto 0):="0000";
variable t7:std_logic_vector(7 downto 0);--:="00000000";
begin
for i in 0 to 3 loop
t6(i)(7 downto 0)<=("00000000");
end loop;
 for j in 0 to 3 loop
  and_1(i)(j)<=(x(i) and y(j));
 end loop;
end loop;
t6(3)<=  "0000" & and_1(0);
k:=0;
for i in 2 downto 0 loop
 t6(i)<=t2( i downto 0) & and_1(k+1) & t2(k downto 0);
 k:=k+1;
end loop;
 t6(4)<=t6(4)+t6(i);
end loop
----just tried this alternative which too dint work---
--  t6(4)<=t6(0);
--  t6(4)<=t6(4)+t6(1);
--  t6(4)<=t6(4)+t6(2);
--  t6(4)<=t6(4)+t6(3);
end process;
end Behavioral;
the final for loop for addition is giving me a gig-up.when i try to access one variable inside the array am able to retrieve it but while adding to the same, the total value tends to undefined(XXXXXXXX).
please suggest any modification
thanks in advance
boe
Re: help with simple multiplier
Reply #1 - Sep 6th, 2011, 11:41pm
Samy,
I would expect a variable assignment, not a signal assignment, in the loop (for the summation).
B O E
samy
Reply #2 - Sep 7th, 2011, 4:32am
boe wrote on Sep 6th, 2011, 11:41pm:
Samy,
B O E
thanks a lot B O E it worked!!
