Sep 1st, 2024, 1:15pm
CMFB loop Stability OR design issue? (Read 1062 times)
ssuchitav
Sep 08th, 2011, 8:32am
I am trying to simulate the circuit shown in the attachment. An ideal OPAMP model (dc gain=100dB UGB=1G) is used for CMFB. The input is of 100MHz.
The circuit is showing unexpected rail to rail swing instead of the expected across 1.25V. I have cheked the CMFB loop stabilty and it looks fine.
Please help me in debugging this behaviour.
Thanks in advance for your suggestions.
raja.cedt
Re: CMFB loop Stability OR design issue?
Reply #1 - Sep 8th, 2011, 9:34am
hello,
what is the circuit functionality? is it an amplifer or h-bridge driver for serial comunication? Any how what kind of input you applied? Have you verified DC operating point of output and is it settling to 1.25. Show some inputs and outputs, otherwise very tough to suggest.
One thing i can tell you may be you have applied high frequency signal and may be due to CMFB low BW it is reaching rail to rail.
Thanks.
ssuchitav
Reply #2 - Sep 8th, 2011, 9:59am
please see the loop ac response. It's H bridge driver for serial communication.
raja.cedt
Reply #3 - Sep 8th, 2011, 10:42am
hello,
this looks ok. But whats the input data rate you are appling, try to apply very slow datarate, then if you are getting no problem it might be the problem with slow CMFB.
Could you please show input and out data.
Thanks.
raj.
raja.cedt
Reply #4 - Sep 8th, 2011, 10:44am
hello i forgot to ask, you have used opamp with UGB 1e9, but still your maginitude plot is showing LBW is 1e9 how come is no bosy in the loop is not offering any poles?
Thanks.
rfcooltools.com
Reply #5 - Sep 8th, 2011, 11:29am
ssuchitav,
In regards to your bode plot.  it appears that your system has three poles before unity gain which would normally be a bad thing for stability.
Also, Could you provide more detail about your setup?
The phase is initially 0 degrees.
This could be that the excitation source polarity relative to the measured is the reason
Or that you have positive feedback at DC to around the point where your gain is below unity.
http://rfcooltools.com
