ssuchitav,
In regards to your bode plot. it appears that your system has three poles before unity gain which would normally be a bad thing for stability.
Also, Could you provide more detail about your setup?
The phase is initially 0 degrees.
This could be that the excitation source polarity relative to the measured is the reason
Or that you have positive feedback at DC to around the point where your gain is below unity.
http://rfcooltools.com
