Aug 16th, 2024, 11:32am
How to choose transistor sizes in CMOS PA (Read 5930 times)
LaTeX
Sep 08th, 2011, 11:46pm
HI,
   I'm design a 65nm CMOS PA for WiMax with on-chip transformer as the output impedance transformation network. The maximum output power is larger than 30dBm. I'm confusing that how to choose the transistor sizes. As we know, if the output power is very large, transistor sizes must be large too. But how can I know what the accurate sizes are with an fixed maximum output power?
Thank you!
prakash@191
India
Re: How to choose transistor sizes in CMOS PA
Reply #1 - Oct 19th, 2011, 12:17pm
The length of the transistor should be not changed as far as i know. Because the technology has to to maintained constant.
For the less power dissipation you should have more width for a given transistor.
Let me know what you mean by accurate sizes.
watson822
Taiwan
Reply #2 - Oct 26th, 2011, 3:56am
I have this question before. In my opinion, under fixed Vcc and required output power, you can get bias current Ic from load-line principle. Then, choose transistor size based on the current density of metal trace.
LaTeX
Reply #3 - Oct 26th, 2011, 4:56am
prakash@191 wrote on Oct 19th, 2011, 12:17pm:
I mean when supply voltage and maximum saturated power is given, how can I choose the transistor width? thx
LaTeX
Reply #4 - Oct 26th, 2011, 4:59am
watson822 wrote on Oct 26th, 2011, 3:56am:
would you give some suggestions for the load-line simulation?
how to set the simulation load R? R equals Rload? or the optimum Ropt?
Thank you!
Reply #5 - Oct 26th, 2011, 11:49am
A load line?
That is not a simulation. Please look the subject
up in a basic transisotr level design textbook.
This is going to be a good way to get a basic operating point for a first pass at the design.
To be more helpful, you need to be more
specific about what you need.
weber8722
Reply #6 - Nov 17th, 2011, 8:23am
The load line concept is good for PA's! I would look at the transistor saturation voltage. If it should be low for good efficiency (like 150mV), than maybe the transistor Cgs becomes large and speed, gain low. So a compromise it needed - also for best reliability. At the end not all can be really simulated... Huh
