Sep 2nd, 2024, 11:16am
Programming Hspice ~ (Read 5246 times)
yuyulu
Sep 21st, 2011, 8:08pm
hello
does sb know how to implement a full adder?
i need a hspice code and circuit diagram
Smiley
raja.cedt
Re: Programming Hspice ~
Reply #1 - Sep 22nd, 2011, 7:22am
hello hspice is a circuit simulator..))
Mohammad A Maktoomi
Reply #2 - Sep 22nd, 2011, 9:44am
Hi
Circuit diagram of CMOS full adder is available in books such as Rabaey and  Weste/Harris.Or type "CMOS full adder" in google, you will get images.
I encourage you  try writing spice code yourself. & believe me, its very easy. You can learn spice (by just giving few hours) from Rashid's book.
Reply #3 - Sep 26th, 2011, 6:19pm
a transistor level simulation tool for a digital circuit function?
Well, yes it can be done, but sure you don't want a digital design tool and a functional level simulation?
Mohammad A Maktoomi
Reply #4 - Sep 26th, 2011, 9:48pm
Dear Mr. loose-electron Smiley
pardon my little knowledge, but i think its not about "it can be done". after all, somebody has to design circuits at transistor level so that HDL people use them from library. Delay calculation, power dissipation, all these parameter is evaluated using lovely "SPICE". In case i sound wrong please guide me, as i am not much in HDLs(actually just started learning verilog).
Reply #5 - Oct 1st, 2011, 2:50pm
Well, if you want to go that path then start by defining all the gates you need at the transistor level, and hook it all up. Set up the hirarchy at the higher levels and build from the bottom up.
As the device gets big, the simulations will get slow.
Mohammad A Maktoomi
Reply #6 - Oct 1st, 2011, 8:15pm
Exactly sir. But,blocks like adders doesn't need gates to be defined in spice.one can translate the algo directly to transistor level(in CMOS). i will not be simulating a whole microprocessor using spice.Spice simulation (in digital design) is perhaps limited to library creation(digital IC design).one uses spice in designing data-path circuits, for example, as these blocks are critical in deciding the speed of system.
