![](https://designers-guide.org/forum/avatars/fredflinstone.gif)
Best Design Tool = Capable Designers
Well, if you want to go that path then start by defining all the gates you need at the transistor level, and hook it all up. Set up the hirarchy at the higher levels and build from the bottom up.
As the device gets big, the simulations will get slow.
