Aug 2nd, 2024, 1:18am
Why SFDR of my DAC is so bad... (Read 2913 times)
Rocky.Lee
Nanjing,China
Sep 22nd, 2011, 7:27am
Hi,Everyone.
I've designed a 6-bit 1.2GHz DAC . And the SFDR test results make me very disappointed.
Results show as below(all results are tested in case of Fs=1.2GHz):
fo=10MHz     SFDR=-39dBc
fo=101MHz   SFDR=-31dBc
fo= 301MHz  SFDR=-24dBc
fo=399MHz   SFDR=-26dBc
Why my SFDR is so bad?
Need help...
Thanks.
Rocky.Lee
raja.cedt
Re: Why SFDR of my DAC is so bad...
Reply #1 - Sep 22nd, 2011, 8:48am
hello,
what kind of architecture, is current steering? how SFDR is faling with frequency? i think at very lower frequency it should be close enough to realistic value, but if your drivers (which drive diff pairs and other timing stuff) are not good it falls very fastly with frequency, i faced this once. So please give more info.
Reply #2 - Sep 26th, 2011, 6:27pm
As frequency goes up, several things start to become significant:
Switch timing.
Capacitive feedthrough of current steering switches.
Start there.
Get your timing to be phase aligned properly to high frequencies.
Minimize your switch size.
Minimize the size of the signals controlling your switches.
Consider compensaating the charge injection associated with the current steering switches.
Reply #3 - Oct 9th, 2011, 5:40am
Rocky,
Is it lab test result? Could you please paste a few FFT plots?
Yawei
