Sep 2nd, 2024, 3:15am
Metal gate (Read 3102 times)
GaAs_si
sandy
Metal gate
Sep 22nd, 2011, 9:00am
Hai
Why Pmos have metal gate why not nmos in tsmc28nm HPL Technology ? Undecided
raja.cedt
Re: Metal gate
Reply #1 - Sep 22nd, 2011, 9:02am
hello,
it is very difficult to say, only foundary can say....
Raj.
harpoon
Hampshire
Re: Metal gate
Reply #2 - Sep 23rd, 2011, 9:02am
I am guessing that if both pmos and nmos gates are used, you will need 2 different types of "metal".
as a result,
it could be more complicated to qualify/stabilize the process (e.g. more variables to control) ?
or cost maybe ?
in any case ... I am also curious to know ... what does the foundry say ?
raja.cedt
Re: Metal gate
Reply #3 - Sep 23rd, 2011, 9:34am
hello harpon,
no need to use two types of metals, because of work function difference if you use same metal you will get different Vth any how it is already with normal cmos process also.
Thanks.
harpoon
Hampshire
Re: Metal gate
Reply #4 - Sep 23rd, 2011, 1:11pm
The different vth is the reason I am suggesting two metal, i.e. If the foundry uses metal gates on both nmos and pmos ... AND want to keep vth the same, then they need two types of metal.
So why then ... Hmmnnn ...
RobG
Bozeman, MT
Re: Metal gate
Reply #5 - Sep 23rd, 2011, 3:25pm
I have no idea, but I remember reading a bit about the subject of metal gates in Spectrum. The hi-K devices need them for some reason. Click Here to get to some of the articles. Maybe the articles will jar someone's memory.
rg
