Aug 16th, 2024, 11:14am
front-end matching noise contributed by itself (Read 2874 times)
baohulu
china
Sep 22nd, 2011, 9:40pm
hi all,
 during matching between antenna and LNA, what software do you use?
 I use a software called smith-chart, it can do matching in smith chart, however,  it can't give a noise and gain simulation. Is there any software can do both?
 besides, when we do front-end matching, how can we considering noise contributed by the parasitic res of L and C? during the matching, at one hand, it needs satisfy matching requirement, at the other, it should introduce as low noise as possible. I have troubles about how to balance both.
 for example, in a T type matching, which is L-L-L connected. the three L all assumed to have Q of 20 in operating frequency, then how can be choose the suitable value of each L to do matching and at the same time reduce total noise contributed by the three L?
 have you ever considering this?
RFICDUDE
Re: front-end matching noise contributed by itself
Reply #1 - Sep 23rd, 2011, 4:43pm
In general the things you need to watch out for are
1. Keep the equivalent series resistance low for matching components connected in series.
2. Keep the equivalent shunt resistance high for matching components connected in shunt.
By "equivalent resistance" I mean the measured real part of the series resistance or the real part of the conductance for shunt components measured at the frequency of interest.
Topology of the matching network can also make subtle but significant differences in NF when dealing with components with varying Q factor.
The following is a good article on the topic
Analyze Matching Networks For Low-Noise Amplifiers
Vladimir Aparin  |  ED Online ID #15569 |  May 2007
Microwaves and RF
baohulu
china
Reply #2 - Sep 25th, 2011, 7:12pm
hi, RFICDUDE
 can you attach the paper? I can't find it.
thanks
RFICDUDE
Reply #3 - Sep 26th, 2011, 5:55pm
Here is the link the the Microwaves and RF article.
http://mwrf.com/Articles/ArticleID/15569/15569.html
