Aug 16th, 2024, 9:14pm
Rise and  Fall time (Read 3668 times)
zahrein
Rise and  Fall time
Sep 27th, 2011, 7:14pm
HI All,
Copied my checkers. I don’t  understand, why my time_vhi &time_vlo is fluctuating at different signals. Another thing is that my rise and fall time also is not  consistant.
module measure_riset_fallt (drive_en, pad);
input pad;
input  drive_en;
// need to  declare  variables so that the  equation of the Rise/fall time  can be calculated
parameter real padh =1.05;
real  time_vhi;
real  time_vlo;
real  rise_time;
real  fall_time;
analog  begin
 @(cross(V(pad) - ((padh)*0.3), 1)) begin
  time_vlo= $abstime;
               @(cross (V(pad) -((padh)*0.7),1)) begin //3
  time_vhi=$abstime;
// For   rising  time . Calculate between 70% and 30% of the peak  Voltage
   rise_time=time_vhi-time_vlo;
               `AMS_INFORM($display("Rise Time= %e",rise_time))
               end //3
if (drive_en==1'b1) begin //1
@(cross(V(pad) - ((padh)*0.7), -1)) begin
  time_vhi= $abstime;
@ (cross (V(pad) -((padh)*0.3),-1)) begin
  time_vlo=$abstime;
   fall_time = time_vhi - time_vlo;
               `AMS_INFORM($display("Fall Time= %e",fall_time))
Re: Rise and  Fall time
Reply #1 - Sep 27th, 2011, 11:43pm
Your code was unreadable and I know it is unlikely that you will get many responses if people cannot easily understand your code, so I took the liberty of reformatting it to make it easier to understand:
input pad;
input drive_en;
parameter real padh = 1.05;
real  time_vhi, time_vlo, rise_time, fall_time;
analog  begin
    @(cross(V(pad) - padh*0.3, 1)) begin
	  time_vlo = $abstime;
    @(cross(V(pad) - padh*0.7, 1)) begin
	  time_vhi =$abstime;
	  // For   rise  time . Calculate between 70% and 30% of the peak  Voltage
	  $display("Rise Time= %e",rise_time);
	  @(cross(V(pad) - padh*0.7, -1)) begin
		time_vhi= $abstime;
	  @(cross(V(pad) - padh*0.3, -1)) begin
		time_vlo=$abstime;
		$display("Fall Time= %e",fall_time);
First a few generic comments:
  • One problem with this code is that you put cross functions inside an if statement. That is a no-no. And it seems unnecessary. After all, you did not put your rise time code inside an if statement.
  • You did not specify tolerances on your cross functions. If your signals are small, your variation may simply be due to loose tolerances.
  • To get better accuracy, you might want to use last_crossing (see "Time interval measurement" on verilogams.com).
None of this explains the problem you are having, which seems to be due to the fact that your vlo rising edge threshold detection simply fails to operate on every fourth edge. The code looks okay to me, so I suspect the problem is elsewhere.
What simulator is this?
zahrein
Reply #2 - Sep 28th, 2011, 6:06pm
Hi Ken,
Thanks  for  your  feedback and  rearranging my code so that it is  readable. The simulator i used  is  using the  DVE. I believe  most of the Logic  Guyz  use this.
I will  try modify base  on your recomendations but i dont think tolerance play an issue as we  cross on voltages and not the timing.
Will let you know once its successfull. Thanks.
zahrein
Reply #3 - Sep 28th, 2011, 10:51pm
Manage to fix it.  The "begin" and  "end" have some disorganize. Here are the  Codes and the waveform pics.
input pad;
input  drive_en;
real  time_vhi;
real  time_vlo;
real  rise_time;
real  fall_time;
analog  begin
@(cross(V(pad) - (padh*0.3), 1)) begin
time_vlo= $abstime;
@(cross (V(pad) -(padh*0.7),1)) begin //3
time_vhi=$abstime;
end //3
// For   falling   time . Calculate between 70% and 30% of the peak  Voltage
@(cross(V(pad) - (padh*0.7), -1)) begin
time_vhi= $abstime;
@ (cross (V(pad) -(padh*0.3),-1)) begin
time_vlo=$abstime;
Reply #4 - Oct 7th, 2011, 7:45am
zahrein wrote on Sep 28th, 2011, 10:51pm:
It always helps me keep begin/end straight if I use proper indentation or formatting, as Ken showed you.  (You need the "code" tag in the forum, so that spaces aren't combined.)
