Jul 17th, 2024, 3:18pm
Can't Figure Out Issue (Read 6715 times)
Chippo
Oct 01st, 2011, 9:05pm
Hi, so i am trying to convert a 4x4 bit unsigned multiplier into a 5x5 signed multiplier. The way we are to be doing it is that we just have to check the sign bits and 2's complement any number that is most significant bit 1 and 2's complement end products if necessary. My issue is that I can't seem to call the 4x4 bit multiplier in my 5x5 signed multiplier. This is the error:
Error (10170): Verilog HDL syntax error at s_mult5x5.v(19) near text "u";  expecting "<=", or "="
Here is the code of my 5x5 multiplier:
module s_mult5x5(clk, st, mplier, mcand, prod, done);
     input clk;
     input st;
     input [4:0] mplier, mcand;
     output [8:0] prod;
     output done;
     wire x, y;
     reg done;
     reg [8:0] prod;
     always @(posedge clk or posedge st)
     begin
     if (mplier[4])
           x = ~mplier[3:0] + 1;
     if (mcand[4])
           y = ~mcand[3:0] + 1;
     mult4x4 u (clk, st, mplier, mcand, prod, done);
     if(mplier[4]^mcand[4])
                 product = ~product + 1;
Re: Can't Figure Out Issue
Reply #1 - Oct 2nd, 2011, 7:44am
You should move the instantiation of the 4-bit multiplier outside of the always block.
Chippo
Reply #2 - Oct 2nd, 2011, 8:48am
Hey Ken, thx for responding. After moving it out of the always block it let's me call the function, but now i am getting other errors on my last if block.
Error (10170): Verilog HDL syntax error at s_mult5x5.v(20) near text "begin";  expecting "endmodule"
Error (10170): Verilog HDL syntax error at s_mult5x5.v(21) near text "^";  expecting ".", or an identifier
Here's the new code:
     input clk;
     input st;
     output [8:0] prod;
     output done;
     reg done;
     reg [8:0] prod;
     begin
     if (mplier[4])
           mplier[3:0] = ~mplier[3:0] + 1;
     if (mcand[4])
           mcand[3:0] = ~mcand[3:0] + 1;
     mult4x4 u (clk, st, mplier[3:0], mcand[3:0], prod, done);
                 prod = ~prod + 1;
Reply #3 - Oct 2nd, 2011, 10:31am
The if statement has to be within the always block.
I think you do not understand a basic concept of Verilog. A Verilog module can contain behavioral code (in initial and always blocks) and structural code (instantiations). The instantiations are evaluated once before the simulation begins, where the code in the always blocks is evaluated repeatedly through out the simulation. As a result, you cannot mix these two types of statements. Hence, instance statement cannot go inside initial and always blocks, and if statements cannot go outside.
Chippo
Reply #4 - Oct 2nd, 2011, 2:41pm
Hey Ken,
I apologize for asking basic questions while I am missing some basic concepts of verilog since I never really learned it. But I do understand what you said, thank you for the clarification. I will be able to figure it out keeping that in mind when writing hte code. Perhaps you can help me with a code that my teacher wrote. I wrote a testbench to test the code, but am only get xxxxxxxx for the output. I tried tracing through the code to see what the signals are and can't find any errors, but then again I am not an expert in it. Here is the code:
module mult4x4(clk, st, mplier, mcand, prod, done);
     input clk;
     input st;
     input [3:0] mplier, mcand;
     output [8:0] prod; //added
     output done;
     reg done;
     reg [3:0] pstate,nstate;
     reg [8:0] prod;
     parameter s0=4'b0000, s1=4'b0001, s2=4'b0010, s3=4'b0011;
     parameter s4=4'b0100, s5=4'b0101, s6=4'b0110, s7=4'b0111;
     parameter s8=4'b1000, s9=4'b1001;
     reg [8:0] ACC; //accumulator
     //reg M=ACC[0]; //M is bit 0 of ACC; could use 'define
     wire M;
     assign M = ACC[0];
           if (st) pstate = s0;
           else pstate = nstate;
     always @(pstate) //state transition
           case (pstate)
           s0: if(st) nstate = s1;
           s1: if (M) nstate = s2; else nstate = s3;
           s2: nstate = s3;
           s3: if (M) nstate = s4; else nstate = s5;
           s4: nstate = s5;
           s5: if (M) nstate = s6; else nstate = s7;
           s6: nstate = s7;
           s7: if (M) nstate = s8; else nstate = s8;
           s8: nstate = s9;
           s9: nstate = s0;
           endcase
     always @(pstate) //Output (Action)
           case (pstate)
           s0: begin
                 ACC[8:4] = 5'b00000;
                 ACC[3:0] = mplier;
           s1: ACC[8:4] = {1'b0, ACC[7:4]} + {1'b0, mcand};
           s2: ACC = {1'b0, ACC[8:1]};
           s3: ACC[8:4] = {1'b0, ACC[7:4]} + {1'b0, mcand};
           s4: ACC = {1'b0, ACC[8:1]};
           s5: ACC[8:4] = {1'b0, ACC[7:4]} + {1'b0, mcand};
           s6: ACC = {1'b0, ACC[8:1]};
           s7: ACC[8:4] = {1'b0, ACC[7:4]} + {1'b0, mcand};
           s8: ACC = {1'b0, ACC[8:1]};
           s9: begin
                 done = 1'b1;
                 prod = ACC;
           endcase
Reply #5 - Oct 2nd, 2011, 3:31pm
Debugging is an important skill that is learned from practice.
