Chippo
Hey Ken,
I apologize for asking basic questions while I am missing some basic concepts of verilog since I never really learned it. But I do understand what you said, thank you for the clarification. I will be able to figure it out keeping that in mind when writing hte code. Perhaps you can help me with a code that my teacher wrote. I wrote a testbench to test the code, but am only get xxxxxxxx for the output. I tried tracing through the code to see what the signals are and can't find any errors, but then again I am not an expert in it. Here is the code:
module mult4x4(clk, st, mplier, mcand, prod, done); input clk; input st; input [3:0] mplier, mcand; output [8:0] prod; //added output done;
reg done; reg [3:0] pstate,nstate; reg [8:0] prod; parameter s0=4'b0000, s1=4'b0001, s2=4'b0010, s3=4'b0011; parameter s4=4'b0100, s5=4'b0101, s6=4'b0110, s7=4'b0111; parameter s8=4'b1000, s9=4'b1001;
reg [8:0] ACC; //accumulator //reg M=ACC[0]; //M is bit 0 of ACC; could use 'define wire M;
assign M = ACC[0];
always @(posedge clk or posedge st) if (st) pstate = s0; else pstate = nstate;
always @(pstate) //state transition case (pstate) s0: if(st) nstate = s1; s1: if (M) nstate = s2; else nstate = s3; s2: nstate = s3; s3: if (M) nstate = s4; else nstate = s5; s4: nstate = s5; s5: if (M) nstate = s6; else nstate = s7; s6: nstate = s7; s7: if (M) nstate = s8; else nstate = s8; s8: nstate = s9; s9: nstate = s0; endcase always @(pstate) //Output (Action) case (pstate) s0: begin ACC[8:4] = 5'b00000; ACC[3:0] = mplier; end s1: ACC[8:4] = {1'b0, ACC[7:4]} + {1'b0, mcand}; s2: ACC = {1'b0, ACC[8:1]}; s3: ACC[8:4] = {1'b0, ACC[7:4]} + {1'b0, mcand}; s4: ACC = {1'b0, ACC[8:1]}; s5: ACC[8:4] = {1'b0, ACC[7:4]} + {1'b0, mcand}; s6: ACC = {1'b0, ACC[8:1]}; s7: ACC[8:4] = {1'b0, ACC[7:4]} + {1'b0, mcand}; s8: ACC = {1'b0, ACC[8:1]}; s9: begin done = 1'b1; prod = ACC; end endcase endmodule
