vivarf
Thank you rfidea.
The problem is: two LO tones are so far different. For example, if LO tones is 50G and 1G respectively. In single conversion with 50G, the number of harmonic in PSS set-up should be at least 3 (then it will cover 150 GHz noise bands). Now for double conversion with 50G and 1G, the beat frequency is 1G. So number of harmonic PSS set-up would be 150 to cover 150GHz noise bands. The simulator could run forever :(.
