zahrein
I manage to design a VHDL AMS on a linear voltage. The voltage is not linear at all but maybe some improvement on the step size or timing.
The behaviour model is equated as V=IR. In this VHDL AMS, i fix the current and vary the resistor. Hence we will get the Linear voltage.
The code
Testbench
module tb_test_ver(); //testbench module name
wire pina, pinb; // declaring wire input
basic_models_circuit out1 (.p(pinb) );
initial $vcdpluson; //log on vpd file for dve initial #(50000) $finish; //set to run for 50,000ps
endmodule ////////////////////////////////////////////////////////////////
Verilog AMS
module basic_models_circuit (p);
parameter real I =1m; real rinput; integer i; output p; electrical p;
initial begin for (i =0; i <4000; i=i+100) begin #1000 ; rinput = i;
end end analog begin V(p) <+ rinput* I; end endmodule ////////////////////////////////////////////////////////////////////
