Dec 17th, 2025, 12:09pm
Discrete-time (digital) filter modeling for SpectreRF PSS (Read 12125 times)
jupiter28
Oct 04th, 2011, 12:26am
Hi folks,
To avoid running into the "hidden state" errors in SpectreRF, i used the track-and-hold model (from Listing2 by Ken Kundert's document titled "Hidden State in SpectreRF").   Basically, i had a mixed-signal macro model consisting of some analog circuits and digital feedback control (modeled in behavioral Verilog-A) in a closed-loop configuration.
A few "analog-type" registers (state element) were originally declared in my behavioral Verilog-A and SpectreRF complains about them as being "hidden state".  So, I ended up replacing each and every register with the track-and-hold model.  I verified that the functionality of the standalone Verilog-A model before and after the change is the same.   The good thing is that SpectreRF PSS runs to completion successfully.   The bad thing is that i am seeing oscillations in my output voltage, indicating that the oveall system is unstable.
The PAC phase plots also seem to indicate that the phase margin is close to 0 deg.  (phase drops to 180 deg. at very low frequency).
This leads me to wonder if the track-and-hold circuit somehow adds a low-frequency pole to the small-signal response of my original loop-gain transfer function.
This track-and-hold circuit has 2 phases, i.e. sampling and hold.  During sampling phase, a pole is formed by Ron and C.  Typically, this pole is located at fairly high frequency since Ron is small and C is around 1nF or so.    During hold phase, another pole is formed by Roff and C.   It is this pole which worries me since Roff is very large (~10^12 ohm) and C=1nF, meaning that this pole is located at very low frequency.
So,  it appears to me that the track-and-hold circuit actually changes the frequency response of my overall system due to its low-pass filtering action.
The following are my questions:
1.  How can i modify the track-and-hold model so that its poles will be moved to higher frequency ?
2.  SpectreRF supports differential operators (idt, ddt) and Laplace function.  So, modeling continuous-time filter in s-domain is easy.   But, the trouble comes when we model discrete-time (digital) filter in z-domain because SpectreRF does not support the Z function and any register-like constructs in Verilog-A.
So, i am sure people have run into this kind of situation before and really appreciate if any of you can shed some light.
Thanks.
-albert
Re: Discrete-time (digital) filter modeling for SpectreRF PSS
Reply #1 - Oct 4th, 2011, 10:09am
Can you show/describe the overall circuit?
jupiter28
Reply #2 - Oct 5th, 2011, 1:05am
Hi Ken,
The following is the block diagram of my whole system in closed-loop
configuration.
      vin => |   analog circuit                |
         ==> | (feedforward stage)       | ----------> vout
        |                                                        ADC
        |         +=================+       V
        |          |  Digital Filter                  | <-----
     DAC <--- | (feedback control)         |
                   | (modeled in Verilog-A    |
My digital filter contains a few registers (modeled in time domain) and in order to run SpectreRF, i replaced these registers with your track-and-hold model.
-albert
jupiter28
Reply #3 - Oct 6th, 2011, 7:44am
Hi Ken,
In your track-and-hold model (Listing 2 in your document titled "Hidden State in SpectreRF), you mentioned that the only nonideality is the finite aperture time and a very small amount of droop.   How much is the droop ?
Is it due to the leakage caused by the 10^12 ohm resistor (in parallel with the holding cap) ?
In other words, during the hold phase, the charge stored on the capacitor will slowly leak through the large resistor to ground.
I wonder if this droop will actually affect the DC gain across the track-and-hold model.  Ideally, we want the gain to be one.   But, due to the potential leakage, the gain can be less than one.
-albert
jupiter28
Reply #4 - Oct 12th, 2011, 9:06am
After replacing my discrete-time filter with the equivalent continuous-time filter, the PAC loop gain magnitude and phase plots are correct and consistent with that from my Matlab sim.
So, this leaves 2 possibilities.  Either i am not modeling my discrete-time filter correctly -or- for some reason, the PAC signal cannot get through certain block in my closed-loop system and the PAC amplitude at the output is zero, resulting in a lower DC gain.
1. For possibility #1, verified that the unit-step response of my digital filter using ideal sample-and-hold is the same as that using "behavioral" registers in Verilog-A.  Also, ran PAC on the standalone digital filter using ideal sample-and-hold and the PAC magnitude and phase plots are consistent with those from my Matlab sim.
2. For possibility #2, since the output of my digital filter directly feeds into a PWM modulator (with a periodic sawtooth waveform) generating a 50% duty cycle in steady state,  i wonder if the gain reported by PAC is also scaled by the duty cycle.    It is because SpectreRF operates on continuous-time signals and for sampled-data system, SpectreRF is computing the Fourier coefficients and scale them by the duty ratio.  Hence,  the fundamental Fourier coefficient will not be 1.
Any clues or comments ?
Reply #5 - Oct 12th, 2011, 11:13am
If the PAC analysis is observing the PWM signal, then yes, the reported gain will scale with the duty cycle.
jupiter28
Reply #6 - Oct 13th, 2011, 7:58am
Hi Ken,
Thanks a lot for your comment.   However, my PAC analysis is observing the output voltage of my pwm switching converter, i.e. the small-signal gain is d(Vout)/d(Vfb), where Vout is the output voltage of the switching converter and Vfb is the feedback voltage.
To run PAC, I inserted a vsource (dc=0 pacmag=1) between the output voltage and the top feedback resistor which is along the feedback loop.
The interesting thing is that when i replaced only the discrete-time filter with the "equivalent" continuous-time filter, everything looks correct.  But, as soon as I plug my discrete-time filter back into my closed-loop system, the DC gain drops by approx. 60B and the single dominant compensated pole is shifted out.    In both cases, the output of the filter directly feeds into the PWM modulator.
On the other hand, i also ran PAC on the discrete-time filter alone and the PAC magnitude and phase plots are correct.  I even ran the unit-step response on this filter and the result is the same as that from my Matlab simulation.   So, i am quite confident that my discrete-time filter is modeled correctly.
I guess I am still trying to get down to the bottom of this issue.   I really appreciate if you can shed some light here....perhaps,  I did something stupid here.
Reply #7 - Oct 13th, 2011, 1:49pm
If you would like an answer, you need to learn how to ask a question that is answerable. Meaning that you have to anticipate what information is needed and provide that information. If you miss something I will ask for it, but right now we are so far away I have no idea what to ask for. All you have given me is a overly simplified block diagram. I have no idea what your circuit does, what you are trying to measure, and why you think the results you are getting are wrong.
jupiter28
Reply #8 - Oct 15th, 2011, 2:37am
Hi Ken,
Please see the attached pdf file for my closed-loop system, consisting of an idealized PWM switching regulator with a digital feedback network.
In the diagram, S/H is the ideal sample-and-hold model i borrowed from your document.
As you can see, there are actually 2 loops here, namely an outer loop with a feedback resistor divider and an inner loop within the digital filter.   Does PAC support this kind of two-loop system ?    To order for PAC to do its job right, what changes do I need to make in my closed-loop model ?
Originally, i coded everything under the digital filter in one single Verilog-A model.  To enable debugging, i flatten it out now, therefore exposing the smaller feedback loop within the filter.
I really hope this diagram gives you a better idea of my problem.
Thanks in advance.
Reply #9 - Oct 18th, 2011, 9:36am
What are the frequencies of the S/H clocks and the PWM?
How is the logic represented? Is it at the transistor level, or are you using models for the logic?
jupiter28
Reply #10 - Oct 18th, 2011, 5:33pm
1. The frequency of the S/H clocks and PWM are the same which is 1MHz.  In other words, phi1, phi2 and the sawtooth waveform (as shown in my diagram) are running at 1MHz.
2. The function of the logic is a simple non-overlapping clock generation which prevents both switches (in the switching regulator) from turning on simultaneously.  It is at the transistor level.
To summarize, my simulation model is a mixed-mode model, consisting of the following components.
a.  analoglib->vcvs
    gain = 1  for subtractor
    gain = a or b   for multiplier
    gain = 1000   for PWM modulator
b.  your Verilog-A model  for S/H
c.  analoglib->R, L, C   for RLC passive components
d.  analoglib->switch  for ideal switches in switching regulator
e.  digital_lib->buffer, inverter, etc.   for the digital logic (at transistor level)
f.  analoglib->vdc   for PAC source (dc=0  pacmag=1)
g. analoglib->vsource  for all the voltage sources, e.g. sawtooth waveform.
Please feel free to let me know if you have any further questions.
Reply #11 - Oct 19th, 2011, 4:28pm
I suspect that your problems stem from your use of models from digitalLib. I don't know, because I have not seen them, but I expect that they are not capable of passing a small signal, which is needed if you want to run PAC analysis and have the signal pass through the gates. You might want to replace your digital models with transistor circuits.
