May 18th, 2024, 12:35am
$rdist_xxx not supported outside the analog block in AMS Designer (Read 6210 times)
Oct 09th, 2011, 1:52am
Hi Guys,
I have verilog-AMS code as below. I want to have random variation for cap15.
   parameter real c15 = 5.12p from (0:inf);
  real cap15, ....
   initial begin
     cap15 = ($rdist_normal(1,0,1)*0.001*sqrt(2^10)+1)*c15;
However it stops in elaboration and reports
Quote:
         Elaborating the design hierarchy:
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
       Discipline resolution Pass...
       Building instance overlay tables: ................
ncelab: *E,EXNOSUP (./dac.vams,38|24): In AMS Designer, the shown system function is not supported outside the analog block.
.... Done
ncverilog: *E,ELBERR: Error during elaboration (status 1), exiting.
Unfortunately, AMS designer does not compatible with Verilog-AMS LRM version 2.3 fully. What can I do?
Yawei
boe
Re: $rdist_xxx not supported outside the analog block in AMS Designer
Reply #1 - Oct 10th, 2011, 2:28am
Hi Ywguo,
I'd try the initial_step event.
B O E
Reply #2 - Oct 10th, 2011, 9:38am
Try $dist_normal(). I think that is the name used in the digital context.
boe
Reply #3 - Oct 10th, 2011, 10:37am
The documentation clearly states that $rdist_xxx is not supported in digital contexts.
However, according to the documentation nowadays it generates integers.
B O E
Reply #4 - Nov 4th, 2011, 5:24am
Can't you re-scale the integers from $dist_normal (divide by the largest) and get something close to what you want?
