Jul 17th, 2024, 3:15pm
drawing a slope line in cadence waveform viewer (Read 692 times)
mixed_signal
Oct 09th, 2011, 11:42am
I am using spectre in cadence IC 6. I am analysing a curve in waveformviewer which is initially linear and then is quadratic. I want to find the point at which transition occurs i.e. linear to quadratic . I want to draw a line superimposed on the initial linear curve and then find where it starts bending.
How can I draw a line of arbitrary slope in waveform viewer? Pls suggest a better solution if anybody has one.
Thanks Smiley
rfidea
Europe
Re: drawing a slope line in cadence waveform viewer
Reply #1 - Oct 9th, 2011, 12:55pm
A workaround that maybe will work is to generate a signal in your testbench that have the correct slope. Use for example a vpulse source from analogLib.
mixed_signal
Reply #2 - Oct 9th, 2011, 2:30pm
Thank u rfidea! I am still looking for an alternative solution primarily for waveform analysis which the sw provides Smiley
