Do you run corner analysis with Analog Design Environment? In ADE, the name for stb analysis is stb, and tran for tran analysis, ac for ac analysis. So the user cannot set more than one stb analysis if you work with ADE. However, you'd better try Ocean or other scrip language.
--Yawei
