Jul 17th, 2024, 5:44pm
how to plot gate capacitance versus gate voltage (Read 5680 times)
mixed_signal
Oct 11th, 2011, 7:28pm
HI, I want to plot gate capacitance versus gate voltage of a mos . i am using hspice. How can i do it?
Re: how to plot gate capacitance versus gate voltage
Reply #1 - Oct 12th, 2011, 10:05am
You can do a nested sweep -- run an ac analysis with a SWEEP.
raja.cedt
Reply #2 - Oct 13th, 2011, 9:31am
hello,
do ac simulations and find the img(current) through Vgs and find the cap....sweep this for some range of gate voltage
Raj.
mixed_signal
Reply #3 - Oct 15th, 2011, 3:12am
Thank you geoffrey and raja! But what do u mean by img(current). How can I evaluate capacitance from that? i know
i=C(dV/dt)
What kind of AC input shall i use? Is it a ramp so that i know dV/dt.
I m a novice. Pls explain in detail.
raja.cedt
Reply #4 - Oct 15th, 2011, 9:15am
hello,
don't use i=cdv/dt....
1. Do .ac simulation, then measure the current through vgs, in that find imaginary current. That's  the capacitance.
Raj.
Reply #5 - Oct 17th, 2011, 7:35am
It's basic Spice theory -- ac analysis linearizes the circuit, and the current is I = (G + sC) V, where V is the ac magnitude of your source, s is the Laplace frequency -- usually s = jω -- and I is the current you measure in your source.
v1 1 0 3.3 ac 1
is a Spice voltage source from node '1' to ground, dc voltage is 3.3, ac magnitude is 1.  Note that the current you measure is ω times the capacitance.
You should try this with a plain linear capacitor and verify this.
mixed_signal
Reply #6 - Oct 19th, 2011, 1:28am
Thank you so much!
