boe
Hi, So you probe the currents through the voltage sources, right? Here a few hints: * First of all, saving of the (AC) currents must be enabled (ADE: Outputs/ToBeSaved or Outputs/SaveAll). * You can use the Results Browser (ADE: Tools) to check if you have ac results after you ran your simulation. * You can access your results e.g. with the results browser or using IF() in the calculator.
Does this help? If not, please post more details (e.g. what do you use to measure transient current, schematic, ...) - B O E
