raja.cedt
hello, you can design cascode CML buffer and common drain amplifier with 50ohm resistive load, normal circuit. But for Phase noise you don't need any specific amplitude for PN mesurement, it is many times depends on the measurement instrument (some times you have to use attenuator to protect the instrument)
Thanks, raj.
